Dimensions on seal around radial axle on FP transmission
I tried my Oettinger today for the first time in 4 years but after the ride I noticed transmissionfluid leaking. So I took out the transmission and discovered that the seal around the radialaxle was to big. The axle measures around 21mm but the seal has the dimensions 23,9x40x8... Any ideas?
Re: Dimensions on seal around radial axle on FP transmission
Andyyyyyyy !!!!!
Looks like the part I'm questioning has part# b 020 311 113 and is marked with dimensions 40x8. Is this the correct part to be used with the FP transmission? I just can't understand why it is too big...
- andy
- GB 2017
hello,
It's normal, you don't have the right seal !
The seal 23,9X40X8 is used on the 2Y boxes (for Golf MK2 16V).
For the FP gearbox, you need a seal 22X40X8(or 7) !
Best regards,
Best regards,
Wish I knew some nasty French words right now... Andy, do you have the part number for this seal?
- andy
- GB 2017
The VW part number is : 020 311 113
But personly, I buy mines by TTO and the number code is D087 !
Thanks Andy. Can you provide a link to where you get your seals.
- andy
- GB 2017
Sorry. I go to my local dealer !
