[phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3526: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2956) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3528: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2956) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3529: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2956) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3530: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2956) www.passiongolfgti.com • Voir le sujet - G60 qui veut pas démarrer
bonjour j'ai un G60 il démare dificilement et quand il arrive a 1000tour le moteur ce coupe changer filtre a essence sonde CO sonde lamda sonde bleu bobine alumage bougie batterie la pompe marche j'ai de l'alumage au bougie si quelqu'un a une idée
on part du principe,qu'au ralenti,le moteur tourne......???ok?
si oui,vérifie que sur ta bobine HT, tu as de la tension entre las bornes 1 et 15- ou plutot ci possible ,si tu as une vieille bougie ,démarre sur 3 pattes en débranchant un cable de bougie,auquel tu fixe ta "vielle" bougie dont le culot reposera sur une masse,as tu sur cette bougie une étincelle quand tu accélères???
au muiti,lorsque tu veux lancer le moteur,regardes aen volto, entre les bornes 1 et 15 de ta bobine HT, que tu as du jus- si oui,c'est bon-si non, prob sur le Hall ou le "l'équivalent" du TSZ-vérifie la connectique de ces derniers-
je ne connais pas l'allumage spécifique de la G60-est ce électronique avec capteur de Hall et TSZ? si oui,tu as sans doute un de ces éléments qui ne fonctionne pas ... il y a un calculo Digifiant?
bon je vous donne des nouvelles deja je venait de l'acheté bon le gas qui a fait la distribution avais pas caler la poulie alumage et dans la boite a fusible le plus de la bobine étais a moitier couper donc tous vas bien et merci pour votre aide
