[phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3526: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2956) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3528: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2956) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3529: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2956) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3530: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2956) www.passiongolfgti.com • Voir le sujet - reconditionnement Bilstein B6
Moi j'ai fais reconditionner mes Bilstein B6 par la STAC il y a... ... m'en souviens plus mais ça fait un bout de temps et ce dont je me souviens c'est que c'était cher
Mais quand même moins que du neuf, alors...
. Golf 1 GTI + Golf 1 GTD : Y'a pas mieux !!! . Quand c'est bien, faut le dire aussi ! . La connaissance s'acquiert par l'expérience, tout le reste n'est que de l'information. A. Einstein.
Moins cher que du neuf, c'est certain puisque le reconditionnement pour les 4 = 480€. Ca vaut le coup si tu as dèjà les amortos. Mais si tu dois les acheter d'occase, vaut mieux se tourner vers du neuf. Sans compter que d'aprés VIAROUGE il peut souvent il y avoir des surprises avec quelques pièces suplémentaires à changer, voire les amortos irrécupérables.
Et encore ! Je pense qu'il s'agit de cartouches avant B8 car pour les B6, pas de tarif... Ceci-dit, ça a baissé
j'ai commandé deux amortos mardi, reçus vendredi, la dernière fois idem cela dépend vraiment du type de produit A l' epoque chez Sparco c'était terrible aussi
CSG n°69 si c'est pas pris....... «Idéalement nous sommes ce que nous pensons. Dans la réalité, nous sommes ce que nous accomplissons.» Ayrton Senna
Mais même si cela dépend du produit, je n'ai jamais eu un très bon contact avec le vendeur (et je ne suis pas le seul) donc je préfère mettre au courant de futurs acheteurs
Il y a des revendeurs plus sérieux et compétent à mon goût (Pourchier, Viarouge... pour ne pas les citer )
Klem a raison, pour ma part, les durites avia ont mis 2 mois et une semaine à arriver
Et ce malgré, nombres de coups de fils, de mails, une lettre recommandée et c'est l'intervention d'un ami, qui se reconnaitra ,merci, qui m'a permis d'enfin recevoir mon colis
