[phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3526: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2956) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3528: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2956) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3529: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2956) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3530: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2956) www.passiongolfgti.com • Voir le sujet - Tension batterie
J'ai trouvé!! tout va bien, il y avait un mauvais contact sur le + à l'alterno. En insistant un peu au multimètre, je me suis rendu compte qu'il envoyait du jus à la batterie par intermitence.
Merci infiniment de t'être impliqué sur mon souci.
salut! si ton alterno est neuf,il est possible qu'il ne débite rien parce que ses "masses polaires" (inducteurs),ne sont pas aimantées- en premier ,vérifie aux bornes de l'alterno ce que tu as en tension (sur le "gros fil)-après,on verra...-L'alterno?,c'est quelle marque,ampérage?pourquoi l'as tu changé?
avec la tension que tu annonces, ton alterno recharge....par contre,me demande si ta batterie n'est pas fatiguée???(because,la tension devrait etre supérieure)-
pour Freddy:la tension,tu la prends sur la batterie,et/ou sur l'alterno-si tu as une mauvaise masse quelque part,tu devrais avoir une petite différence-
tu peux aussi te mettre en voltmètre,et moteur tournant vérifier combien de MV tu as entre le - bat et la masse de l'alterno-ou entre le + bat et le + alterno....-j'espère que tu piges ce que je dis...????!!!!
ben vi,tu as trouvé!l'excitation ça doit pas etre terrible, et à voir la gueule des 2 cables marrons,c'est pas terrible non plus!mais je pense que tu peux réparer avec des fiches neuves "Faston" male, et une pince à sertir-à tout casser,tu perds un cm de cable....
Bon ce week end j'ai refait le faisceau d'alternanteur (démontage de la broche, changement du cablage avec du bon gros fil et de bonnes cosses à l'autre bout) Verdict 13.6 V (12.6 V avant opération)
Par contre j'ai lu sur un post qu'a 13.5 V on pouvait se demander si la batterie n'était pas un peu fatigué or la mienne est neuve Comme je l'ai déjà dit un peu plus haut j'ai controlé la charge (sur batterie) de une 205 GTI 1.6 de 91 (alternateur 55Amp) en même temps que la mienne résultat 14.5 V
Qui est dans le vrai ??? (charge trop importante sur la 205 et/ou normale sur ma golf)
non,ça dépend en fait du régul d'alterno-certains régulent à 14 volts,d'autres à 14,5-c'est un choix du constructeur,certains estimant que ce n'est pas la peine d'envoyer 20 ou 30 ampères à une batterie au plomb,ce qui n'est pas faux,mais permet de recharger plus rapidement-(et le fait que certaines voitures sont en 45 Ah,d'autres jusque 100 Ah)
la tension max d'une batterie est de 13,2 volts-alors dis toi que lorsque tu as une tension supérieure à ses bornes,c'est que l'alternateur débite-
