1988 Oettinger mk2 from JAPAN
Re: 1988 Oettinger mk2 from JAPAN
That gearbox was buit on nov 6th 1990 and comes from a 16V KR/PL engine, it is a little bit stronger than all the 8V versions: the clutch shaft is 2mm bigger (thus the clutch plate is different!).
PGG へようこそ Makky !
I hope this is good
I hope this is good
Thank you for your informationsbillb a écrit :That gearbox was buit on nov 6th 1990 and comes from a 16V KR/PL engine, it is a little bit stronger than all the 8V versions: the clutch shaft is 2mm bigger (thus the clutch plate is different!).
Thank you, JosJos a écrit :PGG へようこそ Makky !![]()
I hope this is good
I'm really happy to able to share the story with PGG members
Tried fixing pealed headlining
Clean up by using cleaner and wet towel.
Decomposed spongy substance is covering the surface of padding and inside of fabric.
I couldn't stick or glue anything on padding and fabric without removing this
Cleaning padding gently, it turns into whitish and Polystyrene foam is exposed.
Then I used doubles side tapes and started to glue the lining fabric onto the base form
Reinforced the cracked place a little.
Not so bad as I expected !
Quite favorable !
The last part.
Then FINISHED!
I'm really satisfied as a DIY revel quality
I thought that this would be a hardest part of the restoration, but it went pretty smoothly
Quite favorable !
The last part.
Then FINISHED!
- Philippe
This is a really good job.
Modifié en dernier par Philippe le mar. 5 mai 2015 20:11, modifié 2 fois.
great !
thank you for this report
- andy
Very interesting. !
But I hope that the glue of the double face will hold with the warmth.
Great!
It was not easier to deposit it to make this operation ?
It's not certain but I chose the one which can be used in outdoors and durable under high temperature.Andy a écrit :Very interesting. !![]()
Anyway, let's see what will happen
The key is how to remove the spongy things thoroughlySebLM a écrit :Great!
The fabric can be spread well in the warm weather and fit easily.
The main thing being that all the old glue was removed to assure a good behavior of the fabric in time.
- Bils
- Dupond
The 84 2000e/16v is inbelievable!
C'est clair ! magnifique. A mon gout il lui manque les bandes latérales
Would be perfect with side stickers !
Si j'ai bonne mémoire, les premières versions de 1984 avaient l'aspect d'une Golf CL, donc sans les bandes latérales!
- Philippe
Tout-à-fait Billb.
PGG est notre ami: http://www.passiongolfgti.com/spip.php?article219
C'est vrai que ça fait un peu dépouillé. Un certain charme très discret.
M'enfin, les roulettes en 14' c'est un peu juste avec 170 vrais chevaux
Oui mais les gommards étaient déjà des semi slicks Pirelli avant l'heure!!
- andy
Dans l'essai de SPORT AUTO N° 272 de septembre 1984, elle n'a effectivement aucune bande latérale !
