1988 Oettinger mk2 from JAPAN
Re: 1988 Oettinger mk2 from JAPAN
Oui, exactement la même, superbe.
Billb, je ne savais pas pour les pneus. Merci.
Extrapolés des P6 et P7?
C'est ce que j'avais personnellement vu en 84 et peut-être aussi dans une revue allemande, mais sans prétendre à une généralité!
makky
Message par makky »
Early Christmas present has come :hourra:
Valve cover gasket x2
Intake manifold gasket x2
Exhaust manifold gasket x4
Distributor cap
Spark plug
Cylinder head bolt x10
16 Ventiler dacel x3 and Oettinger emblem
I realized that Japan is a real wonderland :o
Merry Chrismas then :lol:
makky
Message par makky »
Hello everyone :D
No update for a while, but the car is going to be ready for revive gradually :up:
Cleaning up the inside of fuel tank.
We used waste cloth binding with the wire and wiped the tank.
Took out the fuel pump and casing.
There're no signs of leaking fuel, but I have the other casing which I got it from other 16V and I'm going to swap with it.
Fuel distributor is not in good condition :?
The needle valve is stacking completely and need to disassemble the FD body.
It’s gonna be a waste of time, so I decided to unpack the New FD and Airflow meter which I got few years ago.
There were no plans for the possible future projects and I bought it 'Just in case' at that point. :lol:
Bring back the tank, fuel pump and casing in position.
Moved to the front end.
There're extensive work around the engine bay 8)
I don't know how previous owner handled this car and it's too risky to run the engine now.
So I started to change water pump, generator, intake gaskets, toothed belt and the whole water hose :clindoeil:
Took out the generator and throttle.
Took out the power steering pump.
Remove the compressor.
Tried to remove the water pump... but the long bolt which holding the water pump was stuck completely :bizarre:
I decided to cut out the water pump to remove it :mrgeen:
Such a lot of work to do, but hope it deserved it and that little jewel sang since your last post ! :D
You bought 2000E stickers, but wasn't your engine a 1800E/16 ? :bizarre:
makky
Message par makky »
Thanks Fr@nky.
Everything going smoothly :up:
Actually, the car is in painting process now.
Do you want to see the progress of restoration again?
My car is 1800E/16 as you said.
2000E decal is a present from the shop :lol:
Good Job !
About your spark plugs, i saw NGK C8E on a picture, for my 2000E/16 I've bought CR9EIX and those are better for me.
makky
Message par makky »
Here's little progress.
I could get to the point where I can start the engine at least.
Took off the intake and clean it.
Beautiful port :bisoux:
Then re-assemble the whole parts.
And then, the time has come... :lol:
https://www.youtube.com/watch?v=vTt5ug8NORw
https://youtu.be/vTt5ug8NORw[/youtube]
very good job :up: :bravo:
Nice! Good job guy! I suppose that the spark plug wiring comes from a japanese car?
この仕事のためにブラボー! :bravo:
そして、ビデオをありがとうございました 8) :up:
Jos, tu peux traduire pour les autres! :lol: :lol:
Traduction de Jos:
"Beau travail, plaisant de voir du boeuf cuit en sauce.
Continue comme ca "
:lol:
arf ces algos de google :lol: :lol:
makky
Message par makky »
Ray-2.0 a écrit :Good Job !
Thank you for your advice :D
How do you think CR8EIX for oettinger? CR9EIX will be better?
makky
Message par makky »
billb a écrit :Nice! Good job guy! I suppose that the spark plug wiring comes from a japanese car?
It's not certain, but the shape looks like different from the original wiring.
:bravo: :up: :hero: :hourra: :sage:
Hello Makki,
I just found this on the old forum in 2007, it's a japanese Oettinger, maybe yours a bit younger!
http://www.passiongolfgti.com/newForum/ ... 18&t=14191
